EV0015_MP1583
NRFND
The EV0015 is a 3A Evaluation Board designed to demonstrate the MP1583’s capabilities.
    $25.00 /unit
The EV0015 is a 3A Evaluation Board designed to demonstrate the MP1583’s capabilities. The MP1583 is a monolithic step down (buck) converter with a built in internal Power MOSFET.
The MP1583 achieves 3A continuous output current over a wide input supply range with excellent load and line regulation. Current mode operation provides fast transient response and eases loop stabilization. Fault condition protection includes cycle-by-cycle current limiting and thermal shutdown. In shutdown mode the regulator draws 20µA of supply current.
  • IC Supported 1MP1583
Monolithic IC
GET THIS IC
IC Details
The MP1583 is a step-down regulator with a built in internal Power MOSFET. It achieves 3A of continuous output current over a wide input supply range with excellent load and line regulation. Current mode operation provides fast transient response and eases loop stabilization. Fault condition protection includes cycle?y?ycle current limiting and thermal shutdown. An adjustable soft-start reduces the stress on the input source at startup. In shutdown mode the regulator draws 20? of supply current. The MP1583 requires a minimum number of external components, providing a compact solution.
