EV2228-J-00A
Active
High-Efficiency, 2A, 16V, 800kHz Sync. Step-Down Switch Evaluation Board
    $25.00 /unit
The EV2228-J-00A demonstrates MPS’s MP2228, a high-frequency, synchronous, rectified, step-down converter with built-in high-side and low-side power MOSFETs. The MP2228 offers a very compact solution to achieve a 2A continuous output current with excellent load and line regulation over a wide input supply range. The MP2228 has synchronous mode operation for higher efficiency over the output current load range.
Current-mode operation provides fast transient response and eases loop stabilization.
Full protection features includes over-current protection and thermal shutdown.
The MP2228 is available in a space-saving 8-pin TSOT23 package.
• Wide 6V to 16V Operating Input Range • 100m?/40m? Low RDS(ON) Internal Power MOSFET • Proprietary Switching-Loss–Reduction Technique • High-Efficiency Synchronous Mode Operation • Default 800kHz Switching Frequency • AAM Power-Save Mode • Internal Soft-Start • OCP Protection and Hiccup • Thermal Shutdown • Output Adjustable from 0.8V • Available in an 8-pin TSOT-23 Package
  • IC Supported 1MP2228
Monolithic IC
GET THIS IC
IC Details
The MP2228 is a high-frequency, synchronous, rectified, step-down, switch-mode converter with built-in power MOSFETs. It offers a very compact solution to achieve a 2A continuous output current with excellent load and line regulation over a wide input supply range. The MP2228 has synchronous mode operation for higher efficiency over the output current load range. Current-mode operation provides fast transient response and eases loop stabilization. Full protection features include over-current protection and thermal shut down. The MP2228 requires a minimal number of readily-available standard external components, and is available in a space-saving 8-pin TSOT23 package.
