EV2316-D-00A
New
3A, 19V, Constant-On-Time Step-Down Switcher Evaluation Board
    $25.00 /unit
The EV2316-D-00A is used for demonstrating the performance of MP2316, a fully-integrated, high efficiency, synchronous step-down switch mode converter with the feathered 40uA quiescent current. MP2316 provides up to 3A continuous output current over a wide input supply range with constant-on-time control for fast loop response.
High power efficiency over a wide load range is achieved by scaling down the switching frequency at light load to reduce the switching related loss by constant on time control. Short circuit and thermal shutdown provides reliable, fault-tolerant operation.
MP2316 is available in 2mmx3mm 14-pin QFN package.
• Up to 3A Output Current • 40?A Quiescent Current • 90m? /30m? High Side/ Low Side RDS(ON) for Internal Power MOSFETs • Forced PWM or Auto PFM/PWM Mode Selectable • Programmable Switching Frequency • Power Good Indicator • Cycle-by-Cycle Over Current Protection • Short Circuit Protection with Hiccup Mode • Thermal Shutdown • Stable with Low ESR Ceramic Output Capacitors • Programmable Soft-Start Time • Available in QFN14 (2mmx3mm)Package
  • IC Supported 1MP2316
Monolithic IC
GET THIS IC
IC Details
The MP2316 is a fully-integrated, high efficiency, synchronous, step-down switch-mode converter, featuring only 40? quiescent current. This very compact device achieves 3A continuous output current over a wide input supply range with excellent load and line regulation, and can operate with high efficiency over a wide output current load range. It? optimized for battery-operated applications and applications requiring high light load efficiency. With Constant On-Time control, the MP2316 provides very fast transient response, easy loop design as well as very tight output regulation. Full protection features include SCP, OCP, UVP, and thermal shutdown. The MP2316 requires a minimal number of readily available standard external components with a space saving 2mmx3mm 14-pin QFN package.
