EV2488DN-00A
Active
High Voltage White LED Driver Evaluation Board
    $25.00 /unit
The EV2488DN-00A is an evaluation board for the MP2488DN, a step down converter designed for driving up to 10 white LEDs in series with 330mA current.
The MP2488 is a peak current mode control, fixed frequency regulator to deliver a constant current of up to 2A to high power white LEDs. Its low 200mV feedback voltage reduces power loss and improves efficiency.
The wide 4.5V to 55V input range accommodates a variety of step-down applications, making it ideal for automotive, industry and general lighting application.
The MP2488 is available in small 3mmX3mm 10 pin QFN and SOIC8 with exposed pad package.
  • Up to 55V Input Voltage
  • Drive up to 10 WLEDs series of 330mA
  • Up to 200kHz programmable Switching Frequency
  • Up to 97.5% Efficiency
  • 220m? Internal Power MOSFET
  • 200mV reference voltage
  • IC Supported 1MP2488
Monolithic IC
GET THIS IC
IC Details
The MP2488 is a fixed frequency step-down switching regulator to deliver a constant current of up to 2A to high power LEDs. It integrates a high-side, high voltage power MOSFET with a current limit of 3.2A. The wide 4.5V to 55V input range accommodates a variety of step-down applications, making it ideal for automotive, industry and general lighting applications. Peak  current mode control and 200mV reference are applied for fast loop response, easy compensation and accurate LED current regulation. The switching frequency is programmable with an external resistor up to 200kHz, which can prevent EMI (Electromagnetic Interference) noise problems. The thermal shut down provides reliable, fault tolerant operations. A 12µA quiescent current in shutdown mode allows its use in battery-powered applications. The MP2488 is available in small 3x3mm 10-pin QFN and SOIC8 with exposed pad packages.
