EV3306-G-00A
Active
700kHz Synchronous Boost WLED Driver Evaluation Board
    $75.00 /unit
The MP3306 is a step-up converter designed for driving white LEDs from 3V to 12V power supply. The MP3306 uses current mode, fixed frequency architecture to regulate the LED current, which is measured through an external high-side current sense resistor. The low 202mV feedback voltage and synchronous rectification reduces power loss and improves efficiency.
The MP3306 is turned off if an over-voltage condition is present due to an open circuit condition. The output disconnect feature allows the output to be completely discharged. TheMP3306 includes under-voltage lockout, current limiting, output short protection and thermal overload protection.
The MP3306 is available in small 12-pin QFN (2mm x 2mm) package.
  • 3V~12V Input Voltage
  • Analog Dimming and PWM Dimming
  • Output-to-Input Disconnect in Shutdown Mode
  • Programmable Open Load Shutdown
  • Output Short Protection
  • Low 202mV Feedback Voltage with +/-3% accuracy
  • UVLO, Thermal Shutdown
  • Available in 2mm x 2mm QFN12 Package
  • IC Supported 1MP3306
Monolithic IC
GET THIS IC
IC Details
The MP3306 is a step-up converter designed for driving white LEDs from 3V to 12V power supply. The MP3306 uses current mode, fixed frequency architecture to regulate the LED current, which is measured through an external high-side current sense resistor. The low 202mV feedback voltage and synchronous rectification reduces power loss and improves efficiency. The MP3306 is turned off if an over-voltage condition is present due to an open circuit condition. The output disconnect feature allows the output to be completely discharged. The MP3306 includes under-voltage lockout, current limiting, output short protection and thermal overload protection. The MP3306 is available in small 12-pin QFN (2mm x 2mm) package.
