EV8004-QW-00A
New
13W 802.3af PoE Powered Device Interface with Flyback DC-DC Converter EV Board
    $25.00 /unit
The MP8004 is an integrated IEEE 802.3af PoE compliant Powered Device (PD) power supply solution. It includes a PD interface and an isolated/non-isolated flyback converter.
The PD interface includes detection and classification modes as well as a 100V output pass device. Inrush current limit is included to slowly charge the input capacitor.
The DC-DC converter includes a 150V power switch and is capable of delivering 13W output power with high efficiency. It has an internal soft-start, auto-retry, over current, short circuit, and over voltage protection. It can also skip cycles during light load condition.
The MP8004 is available in thermally enhanced 4x6mm QFN20 package.
  • Meets IEEE 802.3af Specifications
  • 100V, 1? Integrated Pass Switch
  • 420mA DC Input Current Limit
  • 150V, 0.45? Integrated Switch for Power Converter
  • Cycle-by-Cycle Switching Current Limit
  • Integrated 100V Startup Circuit
  • Programmable Switching Frequency
  • Duty Cycle Limiting with Line Feed Forward
  • Internal Slope Compensation
  • OCP, SCP and OTP Protection
  • 4x6mm QFN20 Package
  • IC Supported 1MP8004
Monolithic IC
GET THIS IC
IC Details
The MP8004 is an integrated IEEE 802.3af PoE compliant Powered Device (PD) power supply solution. It includes a PD interface and an isolated/non-isolated flyback converter. The PD interface includes detection and classification modes as well as a 100V output pass device. Inrush current limit is included to slowly charge the input capacitor without interruption due to die heating. The DC-DC converter includes a 150V power switch and is capable of delivering 13W PoE power with high efficiency. It has an internal soft-start, auto-retry, and incorporates over current, short circuit, and over voltage protection. It can also skip cycles to maintain zero load regulation. The MP8004 can support a front-end solution for PoE-PD application with minimum external components, and is available in thermally enhanced 4x6mm QFN20 package.
