EV8902DG-00A
Active
Low Dropout 250mA Linear Regulator EV Board
    $25.00 /unit
The MP8902 is a low-noise, low-dropout linear regulator. It operates from 2.7V to 6.5V input voltage, and regulates the output voltage with 2% accuracy from 1.5V to 5V.
The MP8902 can supply up to 250mA of load current. The MP8902 features thermal overload protection. It is available in a QFN-10 package.
  • Low 250mV Dropout at 250mA Output
  • 2% Accurate Output Voltage
  • Default Output Voltage Set to 3.3V, Adjustable from 1.5V to 5V using an External Resistor Divider
  • Up to 6.5V Input Voltage
  • Better Than 0.001%/mA Load Regulation
  • Stable With Low-ESR Output Capacitor
  • Low 125?A Ground Current
  • Internal Thermal Protection
  • IC Supported 1MP8902
Monolithic IC
GET THIS IC
IC Details
The MP8902 is a low-noise, low-dropout linear regulator. It operates from 2.7V to 6.5V input voltage, and regulates the output voltage with 2% accuracy at 2.5V, 2.85V, 3.3V, or from 1.25V to 5V. The MP8902 can supply up to 250mA of load current. The MP8902 features thermal overload protection. It is available in a 2mm x 2mm 8-pin QFN package.
