EVM3620-Q-00B
24V/2A Mini-Module Regulator With Integrated Inductor Evaluation Board
    $25.00 /unit
The EVM3620-Q-00B is an evaluation board for MPM3620, a synchronous rectified, step-down Mini-Module regulator with built-in power MOSFETs, inductor and two capacitors.
The Evaluation Board can deliver a 2A continuous output current with excellent load and line regulation over a wide input supply range. External AAM pin provides selectable power save mode or force PWM mode.
Full protection features include over-current protection and thermal shut down.
The MPM3620 is available in a space-saving QFN18 (3mm x5mmx1.6mm) package.
  • Complete Switch Mode Power Supply
  • 4.5V-to-24V Operating Input Range
  • 2A Continuous Load Current
  • 200?A Low Quiescent Current
  • Low RDS(ON) Internal Power MOSFETs
  • Fixed 2MHz Switching Frequency
  • External AAM pin for Power-Save Mode Programming
  • OCP Protection and Hiccup
  • Thermal Shutdown
  • Output Adjustable from 0.8V
  • Available in QFN18 (3x5x1.6mm) Package
  • IC Supported 1''
