EVM3680-RE-00A
18V 6A Step-Down Power Module Evaluation Board
    $25.00 /unit
The EVM3680-RE-00A is used for demonstrating the performance of MPS’ MPM3680, a 6A step-down power module with built-in power MOSFETs and power inductor.
High power efficiency over a wide load range is achieved by scaling down the switching frequency at light load to reduce the switching related loss by constant on time control. Over-Current-Protection, Over-Voltage Protection, Under-Voltage Protection, and thermal shutdown provide reliable operation.
MPM3680 is available in QFN 12x12x4mm package.
  • Complete 6A DC-to-DC Solution
  • Wide Input Voltage Range from 2.5V: -- 2.5V to 18V with External 5V Bias -- 4.5V to 18V with Internal Bias
  • 1% Reference Voltage Over 0?C to 70?C Junction Temperature Range
  • Adaptive COT Control for Ultrafast Transient Response
  • Programmable Switching Frequency from 200KHz to 1MHz
  • Support Pre-Bias Start Up
  • Programmable Soft-Start Time with Default 3ms
  • Non-latch OCP, OVP and Thermal Shutdown
  • Output Adjustable from 0.65V to 5V
  • 12 x 12 x 4 (mm) QFN package
  • IC Supported 1''
