EVQ1531-M-00A
Active
Low Power, Triple Output Step-Up Plus Charge Pump for TFT Bias
    $25.00 /unit
The EVQ1531-M-00A Evaluation Board is designed to demonstrate the capabilities of MPS’ MP1531 triple output step-up converter with charge-pumps.
The MP1531 includes a 250KHz fixed-frequency step-up converter and a positive and negative linear regulator. The linear regulators are powered via charge-pumps driven by the step-up converter switch node.
A single on/off control enables all 3 outputs. The outputs are internally sequenced at power-on for ease of use. An internal soft-start prevents overloading the input source at startup. Cycle-by-cycle current limit reduces component stress.
  • 2.7V to 5.5V Operating Input Range
  • 500mA Switch Current Limit
  • 3 Outputs in Single Package
  • Step-Up Converter up to 22V
  • Positive 10mA Linear Regulator
  • Negative 10mA Linear Regulator
  • 250m? Internal Power MOSFET Switch
  • Up to 95% Efficiency
  • 1?A Shutdown Mode
  • Fixed 250KHz Frequency
  • Positive Regulator up to 38V
  • Negative Regulator down to -20V
  • Internal Power-On Sequencing
  • Adjustable Soft-Start/Fault Timer
  • Thermal Shutdown
  • Cycle-by-Cycle Over Current Protection
  • Under Voltage Lockout
  • Ready Flag
  • IC Supported 1MP1531
Monolithic IC
GET THIS IC
IC Details
The MP1531 is a triple output step-up converter with charge-pumps to make a complete DC/DC converter to power a TFT LCD panel from a 2.7V to 5.5V supply. The MP1531 includes a 250kHz fixed frequency step-up converter and a positive and negative linear regulator. The linear regulators are powered via charge-pumps driven by the step-up converter switch node. A single on/off control enables all 3 outputs. The outputs are internally sequenced at power­on for ease of use. An internal soft-start prevents overloading the input source at startup. Cycle-by-cycle current limit reduces component stress. The MP1531 is available in both a tiny 16-pin QFN package (3mm x 3mm) and a 16-pin TSSOP package.
